Gmc Truck Vin Build Sheet Request
Just bought a new-to-me 2006 Sierra, sweet truck with 31,000 miles. None of the documentation came with it, no owners manual, no build sheet, nothing. I found the owners manual PDF online, but would really like to have a build sheet. Can you guys help? VIN is 2GTEK19B461283140. Thank you in advance. -dale
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
