Darn Cel Returned!
big_dawg74
Ok, last week or so I had CEL light come on, mechanic checked it. Code P0449. Replaced EVAP vent valve on Friday. CEL light goes away on Saturday. :D Good times. CEL returns on way home from work tonight. Frustration abounds... :)
Any suggestions??
Re: DTC 0449..... Conditions for Clearing the MIL/DTC
* The control module will turn OFF the MIL during the third consecutive trip in which the diagnostic ran and passed.
* The History DTC will clear after 40 consecutive warm-up cycles without a malfunction.
* The DTC can be cleared with a scan tool.
Sounds like maybe the code was not cleared by a scan tool when the EVAP vent valve was replaced...
Maybe, what you are seeing is the 'History Code' that will eventually clear, or you can try to clear it with a scan tool or obd2 code reader
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
