Anyone Running 295 70 18
yukon25008.1
I just ordered mine 30 minutes ago. I will have them put on my wheels tomorrow. however, they won't be on my truck yet b/c I am getting it lifted soon. I will post pics when i get them back tomorrow.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 285 Guests (See full list)
