2009 Sierra 1500 Upgrade Help
just purchased a 09 sierra 1500 w/t
wanting to know if i can swap over a steering wheel with raido/cruise controls on it and if the features will work, or what else would be needed to make it work. also want to swap from the base cluster to a full cluster with oil pressure gauge and volt gauge.
any help would be greatly appreciated
thx guys
search buddy, alot of guys have done this and pretty easily if your savvy with a sodering iron and patience
searched and wasnt really helpful. see that you can swap the steering wheels, but doesnt say if it will or will not activate the controls to work or not.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
