Warranty Question
If I ever had a warranty issue with my engine, is it possible that GM would not honor the warranty if I had not kept my receipts for oil, filter, oil changes to prove that I had changed my oil as I should have?
I can't answer the question because I honestly don't know...  But that is why I have my oil/filter/lubes all done at my dealership.
I do my own oil changes, and don't keep the receipts.  I've never had any engine problem where I've been in that situation, but if I was, and they wouldn't honor the warranty, I think I I would push them to prove to me that I didn't change my oil.  I'm sure they can tell a difference in internal parts on an engine that has had the oil changed regularly vs one that hasn't.
Probably the best think to do, would be to ask your dealer.
I do all my own oil changes. I think it's up to your dealer...if you have a good dealer you won't have a problem. If your dealer is a buttmunch, you may have a fight ahead of you. Ask your dealer, that's my best advice. I asked my dealer before I did my custom exhaust. He said it's not recommended, but if I had a problem he would take care of me.
I bought my truck used with 11,000 miles on it.  I do my own oil changes and have kept track of all my oil changes and have kept the reciepts.  I don't think I'll have a problem with the dealer giving me a hassle.      :P
I dont keep any of my oil or filter reciepts, I agree it does depend on the dealer! BUT its kind of stupid because you can say you buy your oil and filters at a small autoparts store (regular cash register) and just have someone print up some reciepts! Not saying I would do it or anything, but just kind of dumb on GMs part for asking for reciepts!
