Paco!!!! Ford Question!!!
SnakeEyeSS
(one of)my teacher has a 1998 Ford Exploerer with the 4.6 Cobra Motor in it. She said only a few hundred were made, and that her husband even got in an argument wit a guy over weither they were made or not at a car show, until another Ford guy came up and confirmed that they WERE made. Can you tell me more? :0
I talked to my brother-in-law and father-in-law this weekend. They are Ford "experts" which makes for a very interesting family rival, however, they assured me that no such Explorer was ever produced. There was a Saleen Explorer, but no "Cobra" Explorer, unless someone made one themselves.
my teachers set in belief that she's got the Exploerer with the Cobra motor. She said the saleman told her "this one's got a Cobra motor". I haven't told her what you guys said, but will Tuesday, thanks for the responses.
You need to ask her if you can take a peek under the hood (of the explorer :) ).  You shouldn't have too much of a problem telling whether there's one cam or two in each head.  Also, if it is a cobra engine, it will say so on it (although it might say so even if it isn't).  No one would go to the trouble of installing a cobra engine in an explorer without at least keeping the cobra logo on it.
