Torque Converters On A Budget
Hi guys. I know there are the usual converter manufacturers. Yank, Circle D, TCI etc. But for budget sake I am looking at rev max. They are sold on ebay and have a website. I AM NOT A SALESMAN. I have found no bad reviews only good things. The diesel guys like them. In the link below the LS1 and LT1 guys are beating on them pretty hard. Has anyone here used one or know anyone that has put one in there trucks.
http://www.ls1lt1.com/forum/showthread.php...4279&page=2
A torque converter will help quite a bit. It will free up power. I am only looking at a 2200-2500 stall converter. Enough to let the big block loose but not to crazy. A better converter will have less slippage and generate less heat.
I would just research as much as possible before buying a brand that isn't as popular. I know there was a big stink in the LS/fbody converter market from one company taking some converters made for 4 cylinder cars and repackaging with the correct bolt holes to connect to LS1. Lots of problems. Though I think the company did back the converter and made fixes.
Just something to be aware of.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
