Windshield Washer Fluid Leak
ok, so i always thought that i had a leak in my windshield washer tank because i would fill it up, use it a few times, then my "check washer fluid level" light would come on. well, today after church, in the parking lot i turned it on to clean my windshield, and a guy happened to be standing by my truck, and said when i turned it on, it came pouring out the bottom of my truck. so i got it home, turned it on again and it came pouring out, but some of it was still spraying onto the windshield. i havent gotten a chance to crawl up under the truck to look at it, but does anyone know where to start looking for a fix for this? maybe just a broken hose line?
I bet the little 90 degree rubber boot on the pump motor has dried and split causing low pressure spraying and a huge loss in what you're spraying.
is that a pretty easy fix for a guy who knows almost nothing about vehicles?
The hardest part will actually being able to get your hand down behind the headlights to get to the pump motor. The rubber boot, just pull it off and put another one on, if that IS the problem.
Only thing that you need is to have a second person turning on the washer while you look for the leak. It sounds like it is after the pump in the tank.....and should be a hose with a hole or one of the connectors is rotted.
Should only take 5 minutes to find the problem.....may take longer to actually fix it though. That all depends on what is wrong and if you can get parts for it.
My pump casing had cracked, causing the same problem. Take a good look at it when you have the tank out..
Didn't think of that, but that is also a very common problem for people who put water, instead of methanol, in the tank.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
