I'm thinking of adding 4.10 gears to my V-Max, I'm looking at Motive & Richmond gears. Which are better?
Here is the link for the gears, do these fit my V-Max?
Motive
Richmond
I don't think you can go wrong with either set, but I've heard more about Richmond than Motive. I think the biggest thing is the installation. I've got 4.10 gears in my Vmax and love them :lol:
I thought all v-max's came with 4.10's? Either way, why go from a 3.73 to a 4.10? Did you get larger tires/wheels?
I had Motive 456 in my 08. they were 497 front and rear with install kits off ebay. Didnt have a problem with them. My brother in law has a 94 z-28 and had richmonds installed at the dealer and they make a lot of whining noise. The dealer reshimed them 3 times and could not get rid of the whine. Goto Motive website and get a look at their operation.
How much did they charge u to install the gears?
600, they have to pull the front diff out
I got quoted at 350 to have them installed, is that a good price?
