Help Tires And Wheels
CarlHD
Please someone can help me?
I just want to know if the wheels and tires i'm looking for are OK for my truck. My truck is stock and no lift kit.
The first wheel i'm looking at is the KMC XD Series Hoss
18X9 offset:18mm Backspacing:5.70 inch
The second wheel i'm looking at is the KMC XD Series Diesel
18X9 offset:00mm Backspacing:4.96 inch
On these wheels, i want to mount Yokohama Geolandar AT 275/65R18 load range E
I'm pretty sure your wheels will stick out because stock 18 inch Chevy wheels are 18x8. I'm pretty sure the tires will be ok though.
