Get Some
I bought my 1997-S10 2.2L, 5-speed from my father-inlaw with 27,000k on it in 2004 for 1000$, today it has 515,000k on it with ZERO...yes...ZERO mechanical flaws! starts every time, never broke down, and still gets 26-27 mpg
What oil have you used in it....
Quaker State Full syn. 10-40 in conjunction with a quart of lucas snythetic oil stabilizer and a fram 7000+ oil filter changed religeously be me only never seen a "quick Lube"
Shell bought Quaker State and Pennzoil in 2002 and reformulated them. They went to ILSAC GF-4 API SM in 2004...good stuff.
I use 3.5 qts of QS and a QT of Lucas this combo is perfect i think im going to contact Quakerstate about my truck, ive already contacted GM and they want to document my truck/mileage.
Ive heard of companies like Honda giving customers brand-new cars for this very reason! But they had to give up thier old ones so they could be used in ads or some shit.
yeah thats what im hopin for, but im going to buy a crew cab S-10 by the end of this year and its going to sit in my garage untill the green ghost takes a shit... ill post some pics next week, everyone have a good weekend!!
