Oil Change
fishermonca
please help...i am new to this forum and have a dumb question...i have an 03 2500 and wanted to change the oil today. i just got out from under the truck after finding the filter but the drain plug [i think] looks like it has never been removed. am i wrong? thank u in advance
Why do you believe it never has been removed?
You need to make sure you're looking at the actual drain plug on the pan and not another bolt or plug
It should be on the rear of the pan at the bottom edge. Points straight towards the rear. Probably like a 15mm head on it
well it looks like the drain plug as it is sloped or whatever. it is located in front of the tranny pan. i thought maybe with the oil cooler there might be another way
You got the 6.0 engine?
yes i do.....but the bolt is the same color as the pan and seriously does not look like it has been touched...thx for your help
As I stated in my edit above it should be on the rear of the pan at the bottom edge. Points straight towards the rear. Probably like a 15mm head on it.
ok ty......
i got it.......must have been nervous lol....thanks again!
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,002 Guests (See full list)
