Softening Up The Ride On Burban
I have asked this question on other forums but no one has been able to help me. I have a 1995 3/4 ton suburban that rides really roughly. I bought bilstein shocks and it actually feels worse now. I bought a house at the end of a very rough road and I need to soften up the ride, I really want to keep the burban but if the ride does not get better it has to go, any ideas on how to make it ride better?
Put 300-500 lbs in the back end..... It will make it ride more like a Cadillac..
Jbo
Jbo
+1. Or you could take leaf or two out. But then, what would be the point of having a 3/4 ton vehicle? If you're not hauling or pulling heavy stuff, get a 1/2 ton 'burb with Autoride suspension. You'll love the ride.
Whats your psi in the tires?
if your not loaded or hauling anything, try 42 front 40 rear.. it helped on mine.
i had like 60 in all because there load D, now it feels much better..
I'm not sure on the PSI I will have to check it out, howmany leaves can I take out? There are 6 on there now.I don't use the trusk for any hard work just moving very light equipment around inside it.
