How Do You Guys Like Your '10 And '11 2500hds?
How do you guys like your 2500HDs? I thinking of trading my truck (see left&below) for a 3/4 ton. I have ended up doing a lot more hauling than I thought I would and really like the idea of the heavier transmission, frame, brakes and the 6.0 motor that doesnt have the AFM. While I've enjoyed getting 19mpg on the highway, I would trade it for not having to worry about the oil consumption and lifter issues (nothing major yet, just a slight lifter noise). By the way, what sort of unloaded highway mileage are you guys getting? I would hope with that 6-spd transmission it would be a little better than my dad's '02 2500.
The 2010 is pretty much the same as the 2008 I own so let me say that it's been a great truck with no engine or tranny issues at all, just power door locks and climate control issues being addressed under warranty. Highway I can get between 17-21 MPG (21 comes at 55-60 MPH, 17, at 75+ MPH) If you can still find a 2010 that would be the way to go if you want to avoid that Diesel Fluid crap that GM now has to put in for the 2011+ model trucks, along with Ford and Ram.
Deisel Fluid crap.... Looking at getting the gasser.
Any idea what people are getting in the 6.0L gas? The 6L90 with it's 2 gears in OD, it must do pretty well.
I believe my truck computer says I am getting 17.8?? The truck has 2400KM on it right now. My 08 was getting better. Oh, that's km/100L, I think.
2010 2500HD CC 6.0 3.73 4X4 after 7K miles I am getting 15 to 16 on the highway unloaded. I get 9 to 9.5 pulling 6500 lb travel trailer at 65 mph. I had a similiar 2009 extended cab and had similiar mpg performance. It is capable of getting much worse mpg depending on how heavy your right foot is.
I have an 09 2500HD 6.0 gas. I've had my truck a little over a year now, no issues whatsoever and I am very glad I went with a 3/4 ton silverado. I just can't stand how light duty the 1/2 tons have gotten and how piss poor the ground clearance has become. The 3/4 ton platform inspires lots of confidence and safety when heavy hauling and towing, just can't compare with a 1/2 ton truck. Yea, some guys brag how much their 1/2 ton has hauled, but they never seem to speak about how well their 1/2 ton stopped that big load, and how the truck reacted in higher winds. Just because a vehicle and can a trailer moving doesn't mean it has the capabiltiy to properly stop or control that much weight.
My honest hand calcualted mileage in mixed driving is consistently 11-12mpg unloaded, and the highest I've ever seen has been about 15.8 mpg. Loaded down you can easily dip into the single digits (I've have seen between 8-9 during heavy hauling). This is 100% stock with 3.73 gears and I am not a leadfoot either. Personally I don't care what the mpg is, I didn't buy a 364cid V8 in a 6,000 lbs truck to get good gas mileage.
If your in the market for a truck with more capability, you can't go wrong with an HD silverado.
What are they doing differently in the 2011 Diesel? I am planning on selling my F150 to get a 2500 Diesel but need to do some homework first.
Starting with the 2011 2500, all diesels require a special fluid that cut emissions. This fluid is in a separate tank and usually lasts for 10k miles. You will get a warning when you get low and if you don't refill your truck will run in "reduced power mode". I don't agree with the required fluid but every truck manufactures are doing it to meet the EPA standards. The 2011 diesels interestingly are more powerful and have more torque. I think this is just to make them easier to sell.
Interestingly enough, no one either knows or will say what maintenance the system will require.
Getting back to the original question - in my 2007.5 GMC 2500 HD with the 6.0 I was getting about 14.5 mpg on the highway doing between 70-80 mph. What's weird is as soon as the truck hit 40,000 miles my highway mpg went up 1-1.5 mpg, I didn't do anything different, my driving style stayed the same, my usual route to work didn't change, I don't know what happened, but it was good. But I must say that at 11,000 miles I did get a custom tune for it and that made a world of difference.
I was looking @ some '11 HDs this week & they've partially improved grease jobs.
W/ the steering knuckle redesign, you can actually see the grease fitting for the upper ball joint inboard of the tire. The fitting on the lower ball joint still looked like a PITA.
That "special fluid" is urea, a major component of urine. Just piss in the tank, and you will be fine. :thumbs:
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 706 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
