Vortec Max
whitefrost
thinking of trying a couple of quarter mile passes,2006 6.0 vortec max,4:10 gears,hand held programmer,flowmaster exhaust,how quick should it run?
if youve never dragged before, your first bunch of runs will be crappy. took me a bit of time to get the tree right. if you get ur tree bang on you might hit the 14's...do you have 4:10's? or 3:73's? and urs is a 4 speed too eh? i dont know actually, i think ive watched vids on youtube of guys runnin those times. never seen one in person before so i dunno.
  • 1 month later...
  • 1 month later...
These were stock times on the day of my first oil change. My truck is 2wd with 4.10 axle ratio.
R/T.... .626
60'..... 2.139
330.... 6.120
1/8.... 9.425
MPH... 74.38
1000.. 12.323
1/4.... 14.800
MPH... 90.62
Wow 06sierravmax you really hooked up good, was this on the factory Bridgestone tires? The MPH is low for the ET.
Yes that time was on the factory Bridgestones. I think I held it at 1500rpms then floored it at the light. From what I have seen and heard this is a normal time and mph for these trucks. Here are the three runs I did. The first run was fastest.modifieddr4.th.jpg
Uploaded with ImageShack.us
  • 3 months later...
It should run high 14s, the 6.2 & 6 Speed with exhaust, intake & tune should run low 14s to high 13s.
There is no way that a 6.2 extended cab pickup will run anywhere near 13 second 1/4 mile times, you are talking a 5,300 # vehicle. The exhaust (cat back ) & a intake will only gain you a few horsepower , the factory exhaust actually flows very close to any of the aftermarket makers. All that you will get for your $$$ with a cai & exhaust is NOISE, not performance, a custom tune will help though
Actually, the 6.2 will crack a 13.9 or better with a good tune, intake and exhaust. Most of it comes from relieving the nannies built in for the 6-speed with the tune.
I have 6.2L with exhaust, cold air intake and Edge tuner and mine is a 4X4 crew cab and with traction problems ran 14.4 in the 1/4 mile So yes 13.9 is very reachable.
    Greg3160
    Greg3160
  • Who's Online   0 Members, 0 Anonymous, 416 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
