Tailgate Latch
dsalcido
I'm selling my stock tailgate latch and bezel, they are the factory textured black.
It is in like new condition, taken off my '10 Sierra to replace with a locking one.
I'd like to get $40 shipped, considering GMpartsdirect is $50+shipping, but will accept reasonable offers
Paypal or (local pickup Houston area) only. PM if you would like a picture sent.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
