Some Bluetooth Mod Stuff
loach402
About 6 months ago I did the Bluetooth Onstar VCIM swap described initially in this thread by 07crewsierra beginning with post #34:
http://www.gm-trucks.com/forums/index.php?...78031&st=30
I ended up selling my Acadia earlier this month, but I pulled the bluetooth mod stuff out first. The VCIM (Part #20783877) I have listed on eBay, including the bluetooth antenna (Part# 15938939). The eBay listing is here if you are interested in bidding:
http://cgi.ebay.com/ebaymotors/GM-Bluetoot...=item4aa478e6e7
I also have two different versions of the steering wheel controls with the "talking head" button:
Part # 25851951 - This one has BLUE backlighting (found out the hard way that it was not the right part number for my GMC which has red backlighting)
Part #25851957 - With RED backlighting - this was the one I had installed for the 6 months in my truck and still looks new.
I will sell either of the steering wheel switches for $25 shipped in the continental U.S. PM me if interested in those. Payment would be via Paypal.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
