New Guy With A Question
First off, hey everybody! :flag: I'm the original owner of a 2008 GMC Sierra 1500. It's been a bumpy road since I've had her. Two trees came down in an ice storm a few months after I purchased her, and crushed the cab/windshield. For some reason she was a few dollars short of being totalled by insurance, so they fixed her at the local dealership. I am actually pretty happy with the repair now. At first the lines on the rear door didn't line up right, and with an adjustment it looks as good as new now. I tow a trailer all over the United States and Canada with her. I used to use a Merc. Mountaineer V8, and the differences are just not even comparable. I can say I'm happy to support a great truck made in the USA, and am proud of the GMC for it's quality!
So now my latest problem... :banghead: Well I left the tailgate down and took off the other day.. Well I pinched the trailer's jack handle into the top of my tailgate spoiler, or cap. Well I punched a hole into it.. :) So I figured I'd try to just replace it myself. I found one, but it was for a 2008 silverado.. I'm guessing they are the same. I have a 78' GMC Caballero, and any 78' El Camino parts of the same year minus the emblems work. So I'm hoping these two parts are one in the same.. Anyone know if they are, or even have one laying around? Thanks in advance!! Also noticed I can't make an album, out of room??
I'll post some pics of the damaged truck, and my Cab soon.. ~Chris
Im 99% sure they are the same. As for the Albums they haven't been working for a while. No one knows why and no one seems to want to fix it.
Thanks man for the information!! I can't believe they are different, but for life of me I can't find these for sale anywhere.. They don't even list them as a part as far as I've found, but I know they sell them.. Some people call them "caps" some call them "spoilers", some even call them "plant shelves". :banghead: Probably call the dealer Monday to check the name and price.. Here's my other GMC truck.. :)
Dealer lists it as a spoiler.....part # for a 2008 Silverado is 25844299 cost is $72
Be forewarned tho, the screws that hold it on use a rivet nut in the thin sheetmetal of the tailgate, and when I replaced mine, they spun, so it made getting it off fun.
I ended up peening the metal around the rivet nut, applied a small dab of JB weld, and when it had cured, I put the spoiler back on carefully with a hand driven screw driver...not power driver or you will spin the rivet nut.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
