Window Auto Roll Down
the auto roll is not wsorking when i hold it down but recently when i just tap the button to crack the window it will roll all the way and will stick unless or untill i shut the key off open the door close then turn the key forward or i can unplug the window switch
Switch is bad just replace it.
yeah i just looked they are fair priced i thought maybe the auto roll down had a dedicated wire i could snip for now i was doin 70 in the rain last night i went to crack the window it went all the way down on me
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
