Camping Trip
Went camping this past week and I hauled my parents 28' pontoon boat up to the mountains for the trip. I took some pics of it all hooked up before the trip home. The boat is a 28' bennington tri-toon with a weight of about 4,000 lbs unloaded not including the trailer. Had the bed loaded (not fully) with the rest of the firewood from the trip too. My truck pulls this boat great. Even on the mountain roads with some pretty steep grades it does a fine job, just gotta make sure not to let the engine lug before some of those grades. Doesn't pull like my Dad's Dmax though! He pulls the 35' camper that weighs 8000lbs unloaded and you wouldn't even know it was back there. Anyways, I figured I'd post a few pics just for fun.
I'd love to get a pontoon boat. I'm considering selling my camper and getting one if I can find one at a reasonable price. Were I live now, there isn't enough good camping locations to justify having it. Just not using it like I thought we would. But.. We do have Raystown lake which is 29 miles long of fun boating :confused:
Great photos
They really are great! Awesome boats for all around boating. Perfect for having lots of people and relaxing. But they can also pull tubes and skiers really well. This particular one has a mercury 220 hp inboard outboard and it will really move.
Thats the only way I'd do one if I was able to pull a skier or tube :thumb: I grew up on the lake, my parents started out with a 17' glastron, and upgraded to a 21' century with a GM 4.3 V6 I/O. I use to love to ski/tube.
Pontoon boats have come along way. They used to just cruise slow and steady, now they can manuever and hit speeds that make all the watersports just as fun without sacrificing comfort, storage, etc.
My uncle has a 22' Tri-toon with a 200 Johnson on it and that baby scoots. It runs dead even with my other uncles '05 Four Winns and thats when it has 6 people in it... Its kinda funny actually :confused:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
