Can Somone Identify These Plugs?
Doogie
So I have these plugs on the back of my radio and I know there is a kit that allows for a rear view camera and the voice harness to the VCIM. However does anyone else know what the plugs can be used for?
A pin out would be awesome!! Can I hook up a rear monitor for DVD? Its for my 2008 Equinox. The plugs in question are the two gray ones to the right.
Thanks
Doogie
kinda looks like a rj45 connector
Like for an ethernet computer connection? Its got pins in side and is much larger if that is what I think your talking about.
I don't have an answer for your original question but that is not an rj45.
The first one is for RPO code UUC which is Radio - AM/FM Stereo, Seek/Scan, CD, DVD, Auto Tone, Clock, ETR, MP3, RDS.
1- Left Auxiliary Audio Signal, 2-Right Auxiliary Audio Signal, 3- Left DVD Audio Signal (+), 4- Right DVD Audio Signal (+), 5- Remote Infra Red Signal (+), 6- Video Bright Control, 7- DVD Video Signal (+), 8- Auxiliary Video High Signal, 9- Drain Wire, 10- Video Power Mode Signal, 11- DVD Audio Common, 12- DVD Drain Wire, 13- Remote Infra Red Signal (-), 14-DVD Video Drain Wire, 15- DVD Video Signal (-), 16- Video Drain Wire.
The other connector is for RPO code U3U which is Radio - AM/FM Stereo, Seek/Scan, DVD, CD, Clock, ETR, Navigation, Voice Recorder, MP3.
1-4 Not Used, 5 Vehicle Speed Signal (U3U), 6-16 Not Used
So your saying the left gray one has all the DVD stuff on it? I would like to add the overhead DVD player but I am not sure that this radio supports it. I only have a top CD drive and a MAP DVD drive behind the screen. I have not seen any of the overhead dvd with the nav radio so I don't know if this would even work.
I also see kits on ebay that allow you to put a rear camera for reverse, would that work here too? Its an Equinox Nav Radio if that helps any
Any thoughts?
Thanks!
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
