Bulb Replacement
Not the most common question, but I was wondering before I dig into it. I just replaced the backlights on my steering wheel controls and now I have one burnt out in the fan speed switch on the digital climate control. Are these bulbs the same? Any input would be greatly appreciated.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
