Blue Light On
hardluk1
I picked up a 03 4x4 regular cab pickup at a good price. It has gone to 4 cylinder mode twice on weekends over a month and a half showing a P1513 code the second time. Turn off and restart and it runs fine with the engine light going off after one day or several restarts? Been to the local dealer for code and reading and no reason there for the blue light. Seems a mouse had dinner on some wires in the fuse area under the hood. Thats fixed i think? Now heres the one oddity it has had with the previous too. After the truck is turn off and sets a bit the passing light,(blue light) will be on. Does not seem to draw the battery down after a week or two of setting. Touch the high beam lever and light goes out but will come back on again if not running. Just noiticed also if key goes in, not turned, that the tach makes a very same drop,maybe a 1/32" and blue light also goes out . Just enough if not looking directly at it you would not see it. Head lights work correctly while running and funtions correctly while not running. Nothing seems scewy with anything other than the blue light and the tach twitching and maybe that part is normal. Thanks for any input.
