Why Trucks Are Better Then A Woman
Silverado4x4
When you get tired of your truck you can trade it for a better one and still keep most of your possessions.
Trucks follow orders and operate for extended periods of time with minimal affection and attention.
Trucks don't mind if you drive another truck for a while.
Trucks don't mind if you have another truck just for "running around town."
If you're driving your truck too hard and something breaks, you can just get a new truck.
Trucks have a built-in radio with volume control.
Once you turn off a truck, it stays quiet until you turn it on again.
You can invite your friends over to drive your new truck.
You can use your new truck to pick up women.
Trucks never ask you what you're thinking.
Trucks never get jealous if you drive another truck.
Trucks give a much better return on your investment.
You can go anywhere with your truck, and yet feel free.
A truck will bring you where YOU want to go.
Trucks don't mind if you test drive them before you buy.
You can beat the crap out of your truck and not go to jail.
If you put your foot down it won't censored about it for three days before agreeing to do it.
You only need to put gas and oil in a truck to make it work.
You can lend your truck to a friend and not only will you be willing to drive it again but it often comes back washed and with a case of beer in the back.
You can put your load in a truck and it won't follow you around for the next week.
A truck doesn't care how many other trucks you've been in.
To get a truck hot just turn the ignition.
You don't need to wear a glove to drive some one else's truck.
If you put gas in a truck, just smooth running. Try putting gas in a woman's intake valve and see how she reacts.
You can ride your truck in public without getting arrested.
When your truck is under repair you can use a loaner.
You can look under the hood without getting slapped.
If you have an accident in one, it's less expensive in a truck.
You can ride one for hours before getting tired.
If the seat's too big, you can swap it for a smaller one.
Trucks have big bumpers.
You can always find the door.
You can ride a truck all night.
When you put a truck to work it doesn't complain.
Once you've paid for a truck it's yours to sell.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
