Horn Problems
I did some riding through some pretty deep puddles the other day. Now my horn sounds like a barbie jeep and you can barely hear it. I know there is no mud in it. How long will this take to dry out or is the horn ruined.
Take a look at your horn and you will most likely see that the open end of the horn is facing up. May not be the case, I would remove the horn and turn it several times to drain the water that is currently sitting in it. You did not ruin your horn, but if you let it sit.....
