Costar Bluestar 2010 Is Much Improved
I posted this in the product review section, but I wanted to post it here just in case some of yall never scroll down that far....sorry in advance, mods. I've gotten a lot of questions from people about this product and I figured I'd relay my experiences.
I purchased CoStar's first unit for GM class II vehicles last december, and unpluged it after a week. The phone would arbitrarily disconnect, call quality was awful for the people I was talking to, and there was a 10-15 second delay in hookup on incoming calls.
So I emailed Joe over at Costar and told him I wanted a replacement thinking maybe my particular unit was defective, as I've heard some very good reviews on these things. Joe handled everything quickly and professionally, and offered to warranty it out and send me their new and improved Bluestar 2010 unit.
The unit has a lot of upgrades and is lightyears beyond that zip tied motorola bluetooth module that I bought back in December. It's now fully enclosed in a black rectangular box, and they've added a mini USB port for hooking up to the computer to apply updates and change settings. I've been told that A2DP compatibility (streaming audio through bluetooth) is imminent, and will be applied via a USB update when its available. This is going to be a huge bonus, because I can stop using my motorola t505 unit to stream music and pandora through an FM channel via the T505's FM modulator. The T505 is a great product and I'd reccomend it to anyone that doesn't want to spend the money on a bluestar or travels a lot, but its kind of a PITA to have to switch over to FM when a call comes in, and sometimes the signal can get a bit choppy. All minor complaints really, it works great.
I've read a lot of complaints about road noise and microphone quality for the person on the other end, and really this is easily fixed in about a minute. Plug the unit into your computer and open the settings folder. You can adjust the microphone gain (as well as a lot of other stuff) and it immediately fixes the echo and road noise issues. I found that for my 03 Yukon -12 is the magic number after testing it out on different settings. After I tweaked the mic gain I have had zero problems with the unit, people can hear me loud and clear, and I can hear them perfectly through the onstar channel. The bluestar immediately mutes your music and switches over to phone mode, whereas the old unit would take upwards of 10 seconds to redirect the call audio through the speakers (sometimes it would never get there).
All in all, this is an excellent solution for those of us that don't have factory bluetooth. I'd say the call quality rivals my friend's factory bluetooth in his Mercedes, and the cost is much less than paying for the nav/bluetooth package from a dealership. Good stuff.
bluestar is back ordered right now Joe Costar emailed me to say he should be shipping by November this year so i will get one then
I sent my old Bluestar unit (Motorola 850 zip-tied version) back to Costar in Febuary for repair/replacement. Still haven't received a replacement some 7 months later despite a number of e-mails. I know they're sorting through issues but I'm starting to wonder if I'll ever see anything from them.
  • 11 months later...
Some time ago, I thought there was a post on how to install the bluestar unit with pictures, but I can't find it anywere. Was there such a writeup and if so, does anyone still have it? I have just ordered the unit for my 2004 Tahoe.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
