Squeak When Releasing Brake Pedal
Whenever I release the brake pedal it squeaks. Is there a lube point under the dash for this or is the master cylinder or brake booster going bad?
my gas pedal squeeked and i sprayed WD-40 all over everything down there and it went away. i have stopped many interior squeeks with WD40
Had same issue. Went to remove brake pedal bushing (nylon at top of brake pedal arm). Was not able to remove easily, but did rotate bolt inside of the bushing. NO MORE NOISE. Hasn't made a peep in over a year since then. My girlfriend noticed too. It was terrible before.
Just grab a wrench, crawl in there on your side so you can see up behind the dash, and spin the bolt inside of the bushing a few times. Fixed it for me.
    Joegstfsn
    Joegstfsn
  • Who's Online   4 Members, 0 Anonymous, 545 Guests (See full list)
