Trying To Track Some Noises/vibrations Down
I have a few things i'm trying to track down, any ideas?
1)a slight bang from cold start up to initial driving, the sound reminds me of releaseing the parking brake on a hill..it only does it once, i'm thinking it coming from below the cab or towards the engine bay
2) i have a vibration in the floor, only at idle..i'm thinking exhaust but i'm unsure
3) i have what seems to be some sort of clicking, from the motor (i have no exhaust leaks)
4)clicking under small load, like coasting at 1k rpms or so i can faintly hear it...
thanks in advance
