New From Ga.
Coma_Nomad
Just purchased me a new truck and wanted to say hello for the first time. Had it about 2 weeks now and just had a set of 2009 All Terrain wheels put on it. It has the 6.2 and this thing will get up and go.
Thanks all.
Welcome to GMT! This is the place for all kinds of good information.
This site is why i have the 6.2. :)
Welcome! Where ya at in Georgia?
Forsyth Co.
Welcome...were you get the old style wheels at?
Local Guy on Craigslist
Lol I knew you were gonna ask him that question.
