Lt Or P And Size Change?
Turbine tester
Ok I'm putting on some michelins (LTX m/s2), my truck is a 07 sierra 2wd (non classic) it came with 245 70 17, I think I'm going to go with 265 70 17 do I want to go with the LT or the P?
I do hall a 27 foot camper with it so what can you experienced truck and tire guys tell me.
If planning to haul and tow, go with the LT. LT stands for Light Truck, P stands for Passenger. Check the ply rating on the sidewall to get the load rating. When hauling and pulling I would look for at least a C rated tire. A D or an E would have even more load carrying capacity which means they will be a stronger built tire (comparable strength as a certain number of steel belts and fabric belts) and also an ability to run higher air pressure. Most 3/4 ton pickups and especially the diesels will come with an "E" rated tire and can run about 80 lbs of air pressure. This is necessary when pulling say a 5th wheel trailer around 15,000 lbs.
So calculate what your truck and trailer weighs and buy the appropriate rated tire for the job.
Here is some good info:
http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=55
LT rated tires will have less side-wall play as compared to P-rated tires, even though some P-rated tires can carry the load.
On my '02 YukonXL, I switched to LT tires as I used it to tow often, and it made a huge difference.
LT tires of course will ride a little firmer than a P-rated tire, but it will tow better.
yes, I agree with the previous posts... you have a truck, you want to use it as a truck, so it is good to put truck tires on it..
as mentioned, some P-rated tires will handle the load capacity requirement ... but the LT D-rated and E-rated tires have much stronger sidewalls and tread base providing a much more stable experience when pulling a trailer...
GM puts these P-rated tires on because they ride a softer ... (and they are cheaper).. and they do a good job for many people who use their trucks as lighter duty use. IMO
It's difficult to find LT-C tires, but LT-E are usually offered for just about every make/model truck tire. I'm pretty sure you can run LT-E at the same pressures as LT-C. I plan to use LT tires on my truck when the P-tires wear down, but I've been unsure about what to expect from the C vs E rating. From what I've read, the Michelin MS/2 is a softer tire than many, so a "E" rating at ~45 psi should still ride smooth when not towing and not wear odd (bump up to 55/60 when towing). I don't know the rating on my stock rims (I'm guessing they are rated for 60 to 70 psi, but will check inside when changing tires). Then again, tiny bike tires/rims run 65 psi, so go figure.
Go for the LT. Even a P-rated in a T or H speed rating will vastly improve the handling of your truck. Changed mine (P-265/70/17) from a 113S-rated to 115T-rated. The change in steering response from the extra strength in the sidewall is like night vs day. Drives like an entirely different vehicle.
I have p rated tires on my 2wd Sierra, and I severely overload it once. I have never had a problem with the tires, but could have used some more brakes! I had 44 railroad ties on a trailer, and in the bed. I have since upgraded to a P-rated tire (Hankook DynaPro ATM rf10) that has a better load range (2535 lbs/per tire) It depends on your application. A P rated tire will be lighter than an LT, and give you better fuel economy. P-rated tires are also less expensive. The manufacturer put the P tires on that truck saying its capable of the duties described in the owner's manual. If you are overloading the tires you are overloading the truck. jm2c.
    todd wollemann
    todd wollemann
  • Who's Online   1 Member, 0 Anonymous, 566 Guests (See full list)
