Remote Access
Remote Access????
Do you mean keyless remote or Computer access to a companys network over a VPN?
If you mean keyless entry, there is a procedure for programming the remote that you may have to run through.
  • 1 month later...
Did you try this?
"Transmitter Programming Procedure (Method 1 - No Tools Required) 1.Close all the vehicle doors. 2.Insert the ignition key into the ignition lock cylinder. 3.Press and hold the door unlock switch. 4.While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF. 5.Release the door unlock switch. The doors will lock and unlock to confirm the program mode. 6.Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter. 7.Repeat the previous step to program up to four transmitters. 8.Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode. 9.Operate the transmitter functions in order to verify correct system operation."
Just saw this on the internet tonight and haven't had a chance to compare it to the instructions I have on my web site.  I know those work.  These look like the same procedure.
http://hometown.aol.com/ajstalter/myhomepage/index.html
The info in under my Avalanche link.
I have a new remote from my 2000 truck that I saved.  Can I use the "Transmitter Programming Procedure" to reprogram it so I can use it on my 2002 truck?
I haven't heard of anybody trying that.  But by trying, you will not screw up your existing remotes.  It jsut won't program to your 02 if it doesn't work.
    overspeed
    overspeed
  • Who's Online   5 Members, 0 Anonymous, 1,140 Guests (See full list)
