Classic Chevy Duramax Worn Door Hinges---tooo Loose
got a duramax in shop, just changed the pins and bushings with chevys replacement kit, put the door back together and found its still sloppy, im wondering if theres a place or way to get over sized bushings/pins as these are not working for me,
was allso thinking could weld the holes in then re drill them out but is more work then i had in mind.
other option is to change the whole hinge unit complete but noticed that the hinges are glued on....
if anyone has a simple solution please let me know!
it is a work truck thats beat up fairly bad so it doesent have to be too pritty!
Hinges are welded on. You can get oversize bushings. Most auto part stores carry the kits to repair door hinges
  • 2 months later...
If you have not done it already.
They make a hinge repair kit for the classic body style. It requires that you follow the directions and grind just the peened section on each pin on the hinge after removing the door.
http://www.autobodytoolmart.com/deluxe-hin...vs-p-14211.aspx
You then replace the bushings with those supplied in the kit or oversize bushings you can buy from the original company. The new pins attach to a replacement bracket by screwing into the bracket instead of being pressed in. It makes it very easy to replace the bushings should they wear out again.
Total Auto, Inc is the company. http://www.totalauto.com/nonmenu/education
How do you know if you need the oversize bushings, you have to remove the door first. If the new bushings in the kit are not a tight fit, you will need a larger bushing. great news is you can use the ones in the kit and replace them later in about an hour a door.
I have done the repair. If you can find someone to hold the door, the wiring in the door jamb is long enough to allow you to not have to take the wiring out of the door. I did it by taking the door off because I did not have a door dolly.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
