You may only have 1 or 2. Most everything is "lubed for life". Non-serviceable. :D
Best thing is to crawl under and look at the obvious grease points for zerks. OEM parts may have been replaced by now and you may have zerks whereas OEM didn't.
Ball joints. Upper/lower
tie rod ends
u-joints
If you find 'em. Lube 'em.
Here's an article in the Tech Wiki. It's for the 800 series, but it will give you an idea where to look and what to look for.
http://www.gm-trucks.com/forums/index.php?...icle&id=402
