Park Tilt Mirrors
I have an 09 Silverado Ext. Cab with the OSRV Mirrors that are self dimming, heated, and fold in, however I can't find where I can program the park tilt feature so the mirrors tilt down when the truck goes in reverse. As I read in the owners manual about the mirrors it says it can be programmed in the DIC Customize Setting options but I don't see it.
Does that mean I don't have that option?
You apparently don't have that option.
Park Tilt Mirrors
If the vehicle has the memory package, the passenger
and/or driver mirror tilts to a preselected position when
the vehicle is in R (Reverse). This feature lets the driver
view the curb when parallel parking. The mirror(s)
return to the original position when the vehicle is shifted
out of R (Reverse), or the ignition is turned off or to
OFF/LOCK.
Turn this feature on or off through the Driver Information
Center (DIC). See DIC Vehicle Customization (With DIC
Buttons) on page 3-75 for more information
(With DIC Buttons)
Your vehicle may have customization capabilities that
allow you to program certain features to one preferred
setting. Customization features can only be programmed
to one setting on the vehicle and cannot be programmed
to a preferred setting for two different drivers.
All of the customization options may not be available on
your vehicle. Only the options available will be
displayed on the DIC.
The default settings for the customization features were
set when your vehicle left the factory, but may have
been changed from their default state since then.
The customization preferences are automatically
recalled.
3
that will reset any options you have selected (like lights on when unlocking etc) back to factory settings
mines gonna be a little different, but i hit the button that brings up vehicle serttings, and then its in there. you can change the display units, language, what the truck does when you lock and unlock it, change the alarm notifications aswell, and its got the park tilt mirrors in there too
do you have memory seats?
if not you don't have it..
but it's an annoying ass feature anyway, doesn't work well or consistent.. if need my mirrors tilted down I can do it myself.. hardly if ever need to though, as I know the dimensions and area around my vehicle.. never once curbed a wheel in any car and I can parallel park my Avalanche into a space most Smart car drivers would be afraid of..
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
