Can You Disable The Tire Monitor System On A 2005 Yukon
Is there a way to disable the tire monitor system on a 2005 Yukon? Have reset the system multiple times but the service tire monitor message always returns. Is there a fuse or something that can be removed to disable this system?
I don't know how you would disable it on the dash and/or DIC. The tire pressure sending units in the wheels have batteries that eventually die. You may have to replace a wheel sensor to restore your system. Follow the procedure in the owner's manual to reset the system. If one wheel won't reset, you'll probably have to replace that wheel's sending unit.
