Weathertech Liner Fitment
I just received a second set of Weathertech DigitalFit liners for my 2006 Sierra 1500 as I thought the first set was a poor mold. Unfortunately it's the same poor fit near the accelerator pedal running back towards the seat. The passenger side fits well but the driver's side has about an inch gap near the "hump". For what they cost my expectations were pretty high. Does anyone else have this issue?
they fit perfectly on my 07.
Take a digital picture, call them, and send it to them.
Their customer service is tops.
My wife got a set for her enclave, and the lip protuded too high and the drivers seat was catching on it.
They sent me a second set they claimed they trimmed custom, told me to keep the old ones. All took about a week. They told me that it is mind numbing how much things change even within the same model year when it comes to something needing to fit as tight as these do.
Give it a shot
wierdness does happen. Hope this helps.
Give it a shot
Thanks, I did send a photo that they said it would be forwarded to their engineering department. Their customer service has been very accomodating as they sent another set to check fitment. Unfortunately it was no better and they offered a refund. I really like the design just wish the driver side fit as well as the passenger. There is a buckle in the carpeting but it's not causing the issue. Sure hope I uploaded these photos correctly...
I had an '04 Silverado Crew and I had the WeatherTechs. I did not have the center console. My passenger side fit like yours, but the driver's side had a better fit than you driver's side.
Let me know if you would like to get rid of one set (If you didn't have to send back the first set). I have an 06 Sierra and would like to get a set before winter hits.
Thanks,
Jeff
Center console was the first thing I thought of..... Interesting. I think these are the best mats available.
wow, that does look odd. I am surprised at that. We have weathertechs spread out all over a sierra and enclave. The fit around the mats is impeccable.
Thanks,
Jeff
They are going take back both sets. They have been very accommodating; just seems like an engineering issue with the older body style. I have since purchased a set of Westin Sure Fit liners and the fitment is very good. Similar in design to the WeatherTech but unfortunately they haven't produced the rear mats yet (they claim after 1/1/11).
I have a question and a request for you Frank, do you have a bench seat up front and can you post pictures of how your rear liners fit. I just received my liners and I was told to trim the liner to fit which I did but it doesn't fit right, at least not without trimming more then where the line was.
I have the individual bucket seats and the full length console up front.
The floor liner in the back fits pretty darn well in mine. I hope these pics suffice for now. Will be out of town tomorrow AM until Sat and it is too dark to take pictures now for them to be any good. If you require more detail, let me know and I can take a detail shot of what you are needing....just be Saturday b4 I have time to do it.
EDIT: Actually, looking at your pics again of the back, I see what you mean. I must say, mine seem to hug the rear of the console better than yours do. If you look at the pic with the Du-Ha storage thing, I think you can see that I don't have the fitment problem that you seem to.
Actually, maybe these are better. I went out there and tried taking some and they turned out much better than I thought they would. Maybe these help....
Hope this helps... :mad:
Thanks Frank, I wish I had the center console in my truck. I think I can get it to fit if I trim more off but going by the line that is on the underside of the mat it doesn't fit. I wonder if its because I have the center seat that has the lockable storage in the bottom. I'm sending better pictures to Weathertech per their request.
Hello Sparkey, I had the same problem as you do with the rear liner. I read the directions that stated it needed to be cut to fit as well. Mine looked like yours when I installed them. I went back and cut some more past the little ridge on both sides till the liner fit right around both corners. I know the ridge is there to stop water from flowing off the mat but, I figured that being a high point I would have to be in a flood to get water over that spot.
