Passenger Side Water Leak Ac Related
I have a 2000 silverado V6 reg cab and the heater core went out about 8 months ago. I looped the hoses to bypass the core until recently when it started getting cold and I wanted a heater. I pulled a good portion of the dash before crying uncle and taking it in to get them to finish up with the core replacement. The problem I have now is that when I run the a/c I get a lot of water leaking onto the passenger side floorboard. I have the kick panel removed so I can see that the evaporator core housing and cabin air filter housing are getting very cold and dripping a good amount of water. Any suggestions on what the problem might be and how to fix it? Thanks!
There is a drain that goes out the firewall that should let the water out....but, if the dealership that replaced the heater core didn't get things put back together quite as correct as they should have, it could leak. First thing I'd do is check to make sure the drain is open on the firewall side(stick a wire in there and see if anything comes out). If that doesn't help, I'd take her back to the dealer and see what they want to do about it....their work should be guaranteed and that should be covered.
Travis
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
