More Transmission Knowledge Needed
Greetings all. Perhaps this is an ez one, but since a reference to this observation was made and other posts, thought it would make a good post since its happening to me!
My truck is a 97 2500 with the 80 trans heavy duty. I regularly check fluid levels always hot in park. Anywho, after checking it yesterday it was way way high, like 4 inches over. Gasp! But when checking it again just 5 minutes later it was fine, inside the hatch. This eliminats radiator fluid intake since the reading is clearing jumping around and is sometimes fine. Drained 2 quarts to be sure and started over, well maybe. So before adding more, a few questions. :rollin:
1.) Anybody else experience erratic fluid levels?
2.) Advice about proper filling/measurement methods?
O, and the 2 quarts removed from the tranny plug were examined. about 2 dozen sliver size metal shavings were found. They were silver and if grouped to gether would take up no more area then a dime. Trans shifts fine and fluid appears good, beside levels. A fluid + filter change was done by me 3 months ago with no major finding on plug, but did not look for shavings in fluid. Could be left over from manufacturing since gasket was original meaning this is its 1st change and only 40% was swapped. Anyone else get shavings like this, how much is too much...
Thx in advance!
All gear units make a bit of metal. Also the clutches have a metal content that winds up in the bottom of the pan bothering no one. Not to worry.
Ken
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
