$3.00 Aux Input For The Gmt-800
This is more of a link to a how-to rather than my own. It's so simple.
I am doing it now and will update how it goes.
IF YOU DO NOT HAVE XM RADIO IN YOUR FACTORY HEAD UNIT, YOU CANNOT DO THIS MOD.
Everyone else, read here:
LINKY
Well...it didn't work at first. Why? Because I'm a moron.
I had the wires hooked up wrong. Once I figured out my error, it was fixed...and works so damn well.
Now I can have Pandora in my truck...and that makes me happy.
The pics that follow are just an idea as to how to route the wires an the finished product.
This is a fantastic mod. Works shockingly well...and is DIRT CHEAP.
Also, I'm not senile, I know this should be in the A/V area of this site...but we see so many threads about AUX/iPod inputs here in the FST area...I thought it would work better here due to traffic. I had to D-I-G through GM-Trucks to find the link to the thread on the Avalanche forum...it was not easy to find.
Again, I take ZERO credit for this mod...the boys at the Avalanche Fan Club deserve all the credit.
i use my zune, its cheaper and not plagued with music i don't want to hear...but cool mod
That is the beauty of Pandora...it plays what you like...
And that is the beauty of this mod...any source with a headphone jack can be used!
pandora radio? pandora plays about 25% of what i want to hear and the rest is crap the thing thinks i want to hear...i type in in this moment and end up with paramore, yeah no
thats wicked. would all the decks have wires there for an xm setup or would gm not have run xm wires in a truck not equiped with xm? i know alot of times the harness is the same despite having certain features
You have to have XM....as you tap into the harness that brings the information from the XM tuner to the headunit.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
