Bulb Cross Reference?
i did a quick search here and didnt come up with much, and google showed the 9145 bulb form the gmt800 fog lights to be the same as an h10 bulb. i just wanted to double check that on here to make sure i got the right info. thanks guys
yup I use that site to. the hid I want fit my food doesn't list a 9145 so I'm wondering what that bulb cross references with.
damn smart phone and its swype keyboard is really pissing me off, lol.
thanks bud ill take a look
