2005 Gmc Sierra Z71 4x4 Crew Cab
slortego
The heated seats on driver side have started to cycle on and off.
This problem just started. It happend the last two rotations of my work schedule ( 7 days on & 7 days off ). 1st time - Upon initial startup after sitting 7 days the heater started cycling through all settings on driver side only. It cycled continuously for about the first 45 min. I did not pay attention to the volt meter, I just assumed it was a weak battery, ( approx. 24 months old ) since the problem went away for the rest of my 7 days off.
2nd time - again after 7 days turned off, initial startup and the heater started cycling again. However I did notice this time that the volt meter was varying as well as low as est. 12 and high 14+, I assumed this was due to the draw of the heater. This particular time the problem continued througout my trip home, approx. 2hrs. A few times during the trip the heater cut of and the volt returned to normal, with no varying.
On this trip I decided to pull the fuse on heater and worry about problem once I got home. However
reading the manual while driving is hard!!
Pulled over two times and pulled the fuse I thought was the heater, both were wrong. So i guess you can dismiss this part of the poor attempt to solve my problem. Each time I did this I did turn the truck on and off.
Each time after the first day home, never had the problem again. Now I am at work again and wondering If it will do it again.
While home this time I did have the battery tested and alternator checked by a reputable repair shop. However, I did not witness it.
I do not have any after market added parts, radio's, etc. Nothing plugged to 12volt outlets, etc.
Note: I am having the same HVAC problem with actuator arm on passenger side not cycling as others I have read about in past topics, just a little history. I will post in another topic.
