Tail Light Seal Failed
Looking to replace the passenger side tail light assy as my present one has a lot of condensation in it.
It APPEARS to be rather simple, few screws, transfer bulbs, and pop it back in.....
anything I am missing in "the small print" ?
that is all there is to changing tail lenses. Why don't you just hair dry and reseal the one you have? Unless, your truck is still in warranty of course.
I'm listening :D ..... wasn't aware that one could do that. I figured that once these units fail a seal, it is an exercise in futility to re-seal them... :thumbs:
I just assumed the worst......
AM I looking for somethng obvious, or.... ???? sorry, never had this happen on a tail light. Had a few headlight units over the years that went south, but always under warranty.
Well, it is a little futile. But nothing you can't conquer. Just dry all the condensation and water out of it with a hair dryer, pull and put a bead of sealant around the hole housing where the lenses and base are glued together. It'll take some time, but it's better than paying out the behind for a new housing.
All good points.
Surprisingly, the dealer wants $161 for an OEM unit . Have found a few aftermarkets on-line for around $70. That surprises me a little. Usually, the OEM parts such as these tail lights cost almost as much as a new block. :thumbs:
With winter just having set in, and, considering that this is my daily driver, I MAY just order a new one, and work on the old one to see if I can actually get it fixed.
$70 is one thing --- I was expecting my GMC parts guy to come back and spout out $389 or something like that. Nothing surprises me any more.
I appreciate your input, BTW.
I really wouldn't use anything but oem on the tail lights and headlights, as many of those cheap lights fade and look bad overtime. It's worth the extra oem price to get a quality piece, IMO.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
