Costar 2010 Installed
Costar 2010 delivered today. Installed 5 minutes later. Took about 15/20 minutes. It works great, except the call display with my iPhone 3G, but apparently this is being worked on/??
There were two spare wires from the Onstar module, coax-style on the left side (in the photo). Just curiosity kicking in...
hi Matt the insturtions say if you have two black and two white plugs you have to leave the two coaxial cable pluged into the onstar but if its working okay don't worry about it
hmmm...the way I read it was if the GMLAN signal is located on the black J4 connector it is necessary to wire this signal into the white J1 connector blah blah blah. Nothing was in the black J4 connector, or anything in the black connections at all. I figured the coax was the antennae as well..
if you are you saying you only have the two white plugs then you don't need the antenna's plug in. the way i read it if, you have the two black plugs you would need to leave the coaxials pluged into the on*
Sounds about right to me as well. I wont worry about it!
Thanks
    nolankd
    nolankd
  • Who's Online   5 Members, 1 Anonymous, 449 Guests (See full list)
