Thanks for the tips. I got it paired now. My owners manual doesn't have the commands because the truck never came with bluetooth (2008). Can someone post the procedure to add #'s and use the bluetooth commands? Thanks.
Strange, my '09 didn't come with bluetooth either but it's in my owner's manual. You can download the manual here, but if it's not in the '08 manual you can download the '09 to get the list.
Its because it was an OPTION in '09, so its in your manual. It was never even offered as an option in 07/08. :thumbs:
Ah, good point. ;)
First off...AWESOME POST. Couple questions:
1. I went to EBAY and typed in VCIM. They cost approx. $199. Is this what most are paying to have the BT option?
2. If you get an onstar BT VCIM does it come with a BT antenna?
3. Do we need to match the numbers before we order a VCIM?
Thanks for all of your help!
William
William
1. YES. That's average.
2. SOMETIMES. Make sure to ask. Sometime you have to buy it separately.
3. Match what numbers?
:thumbs:
Yup should work with all the head units in the new style (GMT900)
thank you sir! I need to order and get it in because my USB radio is waiting for me. A guy at the dealership got it for me and is going to re-program.... so i need to get it ordered and in fast before he does the new headunit and he can re-program my VCIM too for the onstar :( Mucho Gracias
PLEASE let us know if you get the onStar working with the replacement VCIM. I don't think anyone has yet. For some reason they "can't" do it if the VCIM did not come with the vehicle from the factory. (But there's GOT to be a way)
I cant see any reason why they cant change the VIN in the replacement VCIM. If the had to replace it because of a fault then they would be able to input the VIN or am I wrong?
I agree. But no one has successfully done it yet. Might have something to do with the fact they are not new-from-factory replacement VCIMs. GM won't actually sell those to the public. Anyone I know that has done this mod, has got a second-hand unit.
I purchased VCIM number 20827036 off of ebay for $199. Installed it into my 2010 Sierra SL, it goes behind the panel that has the ashtry in it. After it was in, I had the red light for OnStar, but the bluetooth worked straight away. I pressed the emergency button on the mirror, and told the operator that it was the only button that worked and about the red light, she passed me on to techsupport.
Techsupport had me on the phone for about 15 minutes while they did some stuff, but the red light remained. The techshupport guy applogized for taking so long, and gave me 100 minutes of phone credit to compensate. He also said I needed to go to the dealer to get it finished.
Booked an appt with my dealer, and took it in on that day and left it. They called about 2 hours later and said it was all done, but it would not be fully working until the next day. I went in to get the truck expecting to pay about $75, but it was no charge.
Next day (actually today) I tried Onstar, the light was green and it connected to the operator, but she said there was still something not activated properly, and passed me on to tech support. Tech support took another 15 min to get it fixed, and they did fix it, Onstar works, green light and all. The tech support guy applogized for the long wait, extended my OnStar another 3 months no charge, and gave me another 130 minutes of phone credit. All in all, I got a total of 230 minutes of phone time, and 3 months free service, and I did not even have to complain. Biggest surprise was the no charge from the dealer though.
Are all phone calls made with the phone itself or are there other controls available?
Not sure I understand what you are asking here. If you mean how do you make cell phone calls with bluetooth, I press and hold the phone button on my steering wheel controls for a few seconds, and when the onstar voice speaks, I say "dial", then wait for the voice to say dial using {insert your cell phone id name here} and it asks for the number, at the beep I just say the phone number, and it completes the call. I understand you can dial by name as well if you program each one in. I know the phone numbers I want to dial, so I just say the phone number.
This is a little unrelated, but can the VCIM out of a 2011 be added to gain the OnStar application use?
Hi There,
Had my 2011 sierra to dealer yesterday trying to get them to order vcim and do the bluetooth upgrade. Thought it was worth a shot. Service manager did some checking and was told by gm corporate they would not ship these parts as they were restricted. He Also said that there was an option coming down the pipe for owners who wanted to upgrade. When asked about the used vcim option he said the programming from the factory for a non bluetooth vcim was different and that was why onstar wouldnt work properly.
This is monumental. Ive done ALOT of research and you're the first guy I've heard that got this working! And with some bonuses to boot!!
Edited by mc7719
Keep in mind he got it working on a 2010 truck.... a truck that had BT as an option.
To my knowledge no one has gotten onstar to work on an 07/08 truck.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
