On* Programming In New Vcim
Does the programming done on the VCIM modification to get on* back have to be done by a GM scan tool or can another from a different vendor work? Did not know if a special GM software had to be used??
I believe this was already answered in another thread of yours...
Communication Interface Module Programming and Setup
Each of the following service procedures require programming or setup procedures to be performed on the communication interface module.
Communication Interface Module Replacement
Note:
• It is critical to use the service replacement Communication Interface Module (CIM) only in the vehicle for which it was ordered.
• Failure to perform the following procedures will result in a red LED, DTC(s) being set, and limited or incomplete OnStar® services
• An OnStar® button-press to the OnStar® call center is not required to complete the procedure.
• It may take up to 24 hours for OnStar® service to become fully activated after performing the procedures.
• Perform the following procedure only once. Repeat attempts of the procedure may result in a delay of the activation process.
• To fully activate an OnStar® module, both the setup and activation request procedures must be completed on all vehicles with AND without an active OnStar® subscription to insure the unit has been setup properly for the vehicle it has been installed into and also to update the OnStar® with the correct unit information.
• To initialize the Turn-by-Turn feature, the vehicle must first be driven 8-16 km (5-10 miles) in order to allow the system to self-calibrate the dead reckoning feature.
• Use of a J 2534-compatible diagnostic tool interface is required when performing the SPS supported OnStar® Activation (ONSA) procedures.
• On vehicles up-fitted with TTY capabilities, it is necessary to perform a power cycle of the OnStar® Interface Module (OTIM), and toggle the TTY mode after completing the CIM installation and setup procedures.
1. Connect the scan tool to the vehicle.
2. Connect the Techline Information System (TIS) terminal to the scan tool.
3. Using the J2534 interface perform OnStar® activation by selecting the ONSA-OnStar® Activation option.
4. Upon completion of the OnStar® activation event (ONSA), disconnect the TIS terminal from the scan tool
5. Select and perform the VCIM-Vehicle Communication Interface Module Setup (VCIM) option, based on vehicle application, using the Scan tool.
6. The default language for the new VCIM is English. To change the language to French or Spanish, access the scan tool.
7. Inform the customer that it may take up to 24 hours for the OnStar® service to become fully activated.
As you can see, if you don't have access to a GM scan tool or the GM programming database, the module will not work after it is put in the vehicle. 90% of GM modules are that way. They have to be programmed using the GM programming database to work.
    Brandon 29
    Brandon 29
  • Who's Online   4 Members, 0 Anonymous, 497 Guests (See full list)
