Grille Question
Are you talking about the GMT900 models? If that's the case, no as the front end sheet metal for those 2 models is completely different.
You can make that fit. All you need is a reciprocating saw and some super glue and duct tape. :(
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
