Leer Cap Sqeeks Bad.....need Help.
Hey Guys,
I have one of the leer 100XQ caps on my truck and i noticed that the cap squeaks when going down the road. Its up near the front portion of the bed rail ( the one that runs parallel to the back window). I want to loosen the cap, raise it up and put some lubrication on the foam / bed rail to eliminate the squeak........but i have no idea what to really use.
Any ideas?
Is it firmly clamped down? If changing the cap tape doesn't correct the noise I would suggest graphite lube spray along the top of the tape. Thank should kill any squeaks.
Have you taken it back to whoever installed it?
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,016 Guests (See full list)
