Transmission Issue?
I got a 1995 GMC Z71, auto,gas. I pulled her onto the highway and hit it. Made 1st, 2nd but it never made it to 3rd, 4th and so on, it just kept revving and doing nothing. Could i cross my fingers and hope for a torque converter issue, or has my transmission burnt out? Reverse had a little bit of a shimmy backing up in the truck and my boss said torque converter at the time. Truck worked perfect the day before. Is there any tests for a torque converter or transmission? I'm left scratching my head but i guess we gotta do what we gotta do. Thanks for the time reading this and for any thoughts you might write down :cheers: Have a gooder
I'm no transmission expert, but I have tore up a few. Sounds like your 3rd-4th clutch is gone. After I lost 3and4 my reverse was pretty quick to go out as well, which it sounds like yours is going to soon.Basically , unless you can rebuild the transmission yourself, the only thing you can do is take it to a reputible transmission shop or start searching for a used on, but in my experiences a used trans isnt worth it, I would go for a compleat rebuild.JMO
Hi ... another guy from Saskatoon here...
it does sound like your 4L60E transmission is going ... these things do have a finite life time ... and it is common for them to wear out somewhere in the range of 200,000 to 240,000 kilometres (130,000 to 150,000 miles) ... if you have more than that on the odometer then you got a bonus!
the only thing you might try yourself is check the fluid level ... but based on what you describe, it sounds like it is worn out.... once the clutches start to go it is common that virtually everything inside the transmission also has considerable wear
When my transmission died, I took my truck to OK Tire & Auto on 8th Street East in Saskatoon (where I get all my auto repair and maintenance work done), and they had the transmission out of the truck (a PITA I heard), total transmission and torque convertor rebuild, and back in the truck the next day. I think they get all their transmission parts through Extreme Transmission Rebuilders which is located behind them in the same building complex.
It ain't cheap, but if the truck is in otherwise good condition it is still cheaper than buying a new truck. Two years ago I paid $1600 for the trans/converter rebuild plus R&R labour, fluids, plus miscellaneous costs, taxes, etc.... and I think it came to about $2600 total, with a one year warranty. I have had no regrets about getting mine repaired.
Looking for a used trans at a wrecker is a crap shoot... you never know what you are getting ... and then on top of that your '95 is a single year unique transmission, so it would be even harder to find a good one at a wrecker.
Good Luck!
Yea i highly doubt that its the torque converter.my 90 gmc sierra has 270,000 miles on the original trans and rear.when it goes it goes cant cry about it.
definitly shot ,another avenue is a GM rebuilt tranny,it comes with a 3yr warranty ,the cooler gets flushed and flow rate thru the cooler is recorded and put on the work order (if done at GM).for warranty purposes
decision time for your 15 yr old truck
good luck from Wainwright ab
My reverse was getting pretty shakey on the truck, like shimmy while backing up. NOW, the darn thing backs up as if it never did nothing, no vibrating while backing up or well nothing, just normal. Is that a hint of a transmission problem? If so why all of a sudden does reverse work prefect? Just asking thats all. I guess it's time for a new one :) I thank you all for your replys, this was very helpful. Happy New Year to all :dunno: Rod, just a question. How much did O.K. charge you for a rebuild? Lata guys and once again thank you.
I had my transmission work done in July 2009 ... the basic cost was $1600 plus R&R, fluids, misc service charges, taxes, etc... and I think the total was about $2600 ... I figured it was a good investment and I don't regret getting the work done...
My reverse was getting pretty shakey on the truck, like shimmy while backing up. NOW, the darn thing backs up as if it never did nothing, no vibrating while backing up or well nothing, just normal. Is that a hint of a transmission problem? If so why all of a sudden does reverse work prefect? Just asking thats all. I guess it's time for a new one :( I thank you all for your replys, this was very helpful. Happy New Year to all :D Rod, just a question. How much did O.K. charge you for a rebuild? Lata guys and once again thank you.
Being a 4L60-E, shifts are (obviously) electronically controlled, therefore it has shift solenoids in it. That being said, the 2-3 solenoid might be fading... I've seen it happen before. The bad thing is since your truck is a 95 it's not OBDII so I don't know if there's a way to retrieve any trans codes or not. Never rule out a clogged filter or valve body either. And then again, it very well could be the clutches. That's what sucks about newer transmissions... instead of being just one thing, it can now be twenty! When a TH350 started acting up on you, it was done and you knew it, no second guessing! Knock on wood I've got 160K on the second build on my 4L60/700R4 (whichever you prefer to call it) and it still shifts great. Good luck!! :troll:
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
