Random Truck Not Pedal Pulsation
As some of you may know I put new front brakes on a lil over a month ago. It fixed the wheel shake and stops on a dime. The thursday before christmas I put on new shoes & drums in the rear. It stops good and fixed all noises. I now notice when slowing down SLOWLY the truck pulsates a bit at times. Not the pedal. The only thing I can think of is when i put the fronts on when i used the clamp to press in the cylinders on the caliper i loosened up the bleeder as i squeezed the cylinders in. Could air have gotten into the line a little? Does anyone know what this could be? Or is this just "normal" on these trucks?
Thanks in advance!
happens only after brakes are warm, when i have been in parking lot traffic
I dont think they are bad. they are brand new and the truck only does it when they are nice and hot in traffic?? so i dont know. they are wagners top of the line that they offer. When i was back home for the holidays a buddy of mine works at oreillys and gave me them at half price. But they are the best oreillys even offers. I even had him throw them on their turning machine to check and see if they were perfect...... and they were :troll:
If air is in the system could it cause this? bad fluid? bad master cylinder? and so on.......? If no one here knows i def do not want to take it to a shop for them to scratch their head and just make me throw money at parts :sigh:
Air could have gotten in, but then the brake pedal would be soft.
Check the rotors and see if they are grooved. I have had metal stick to the pads and groove the rotor. No idea why,but it scraps off the pads without problem.
Also, did you break in the pads? If you did not, the pads may glaze when applying the brakes lightly to stop.
And last, this may be normal for the pads you bought. Some pads do not function very well at light pressures and the lower temps. They work great otherwise but allow the rotor to slip past when you apply very little pressure.
FINALLY! A reply :sigh:
the pedal is not soft. i checked the rotors yesterday and they are smooth as a babies bottom. I broke in the pads per manufacturer specs. maybe with light pressure they will not function well but this is at higher temps...... after lots of stop and go traffic. I even took the pads off and they look perfect. :troll:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
