Front Hub Replacement Z71 Silverado
I need to replace my front left hub on my 2001 Z17 1500 Silverado (215,000 miles, hub ay loose, making noise, not ball joint).
I bought the part today and looked on several forums and it looks pretty simple mechanically. I've seen some trouble areas that keep popping up – such as getting the 32mm nut off (assuming this is the main nut) because it spins the shaft – any suggestions? I don't have air tools and don't have a what someone called a "yoke wrench" - so do I use lots of WD40 with a breaker bar and a 5# mini sledge? Won't the axle spin? How do you keep the axle from spinning? I don't think I want it n 4WD when I'm hammering on the nut and stressing the gears in the case right? Someone also said to be sure to take off the inset retaining washer/ring.
Also, when putting it back on, any thread lock or ???? that I need to put back on the bolts to make sure things stay put. I've never don't drive shafts/suspension type things before so some of the common little things I'm not up on.
Any common problems that pop up or common mistakes (either minor or catastrophic)?
Thanks all!! Greatly appreciated!
i did it on my 2002 gmc sierra 4x4. all u gotta do is take off the brake caliper, rotor and then the axel nut. to take the axel nut off i used a axel nut torque socket and a air gun and it came right off no spinning. next there are 3 bolts in the back that hold on the hub assembly take them off off and hit it with a nice hammer to loosen it up then push the axel off while takin the whole hub off. there should be a abs sensor connection u have to disconnect too. when you put it back on make sure you put thread locker so u dont loose your hole wheel :troll: thats basically it. its not hard to do. i tip i did to make it not spin ( i dont know if it worked or not) but i put it in drive
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
